TE20 Clutch
Michael Underwo
01-22-2001 12:03:02
Having just split my TE20 in half in order to address the sticking clutch, I have a few queries. Firstly I am in need of a new clutch plate and have been informed that many modern cars use an identical plate, (Ford Granada?) can anyone confirm this or suggest a car that does use an identical plate? Secondly I believe that my thrust bearing has seized, but as I cannot rotate it, I'm not even sure if it is a bearing or simply a plane surface, but surely there has to be some form of bearing, correct?. Could anyone kindly confirm whether or not the TE20 is fitted with a thrust bearing and if so any ideas on where one can be acquired, many thanks.
Tom
01-25-2001 10:45:41
 Re: TE20 Clutch in reply to Michael Underwood, 01-22-2001 12:03:02
Your TE20 has no bearing in the fly wheel if thats the one you're talking about. Providing nothing has been changed over the years.
It does have a throw out bearing.
On the sticking - check the splines on tranny shaft. They can get scarred and pitted over time.
Take emery cloth and smooth out.
Tom B
KeithF
01-26-2001 17:34:37
 Re: Re: TE20 Clutch in reply to Tom, 01-25-2001 10:45:41
Tom,
I have a 1948 TE-20 and it has a ball bearing pilot bearing that goes in the flywheel to support the end of the transmission. I might be able to find the number on it as I believe I changed it when I split the tractor in 1997 and redid the entire clutch.
MU
01-29-2001 10:50:03
 Re: Re: Re: TE20 Clutch in reply to KeithF, 01-26-2001 17:34:37
Keith, where did you get the clutch parts from and what was the cost roughly of overhalling the clutch?
taffy
01-22-2001 13:14:37
third party image
I've changed plates/bearings and the p/tvo plate is approx 9inch diameter. The diesel plate is I think bigger.
Your bearing sounds as though its seen better days.
