TO 20 Wiring
Gene Stevens
04-25-2007 02:45:38
I posted this earlier and did not get a response. Can someone tell me if I am on the right track? I have replaced the alternator and amp gauge on my TO 20. It had two off/on toggle switches installed by the previous owner. One switch would let it start�the other I don�t know what it was for. In the process of installing a new single switch using the wiring diagrams posted I have run into a problem if wired as shown I am not able to shut down the engine without removing the heavy wire from the alternator. It will start without it connected but will not charge. If I connect it back or touch it to one side of the switch it will charge. If I connect it back at the end of the day it will discharge the battery overnight. Looks as if I need to replace the switch just to be able to charge the battery and shut down? Any thoughts?
Thanks Gene
Daniel Collings
04-25-2007 15:46:45
 Re: TO 20 Wiring in reply to Gene Stevens, 04-25-2007 02:45:38
I sounds like the alternator wire is hooked to the wrong place. There may be other problems but I'll explain what may be the problem and why. Maybe it will help you understand whats going on and atlease help you get on the right track. It's hard to say without a diagram.
Assuming that the alternator has an internal regulator. The alternator charge wire (+) should go to the amp meter. The other wire on the amp meter should go straight to the battery (+). I have seen it connected to other locatoins that should be common to the battery (+) without anything inbetween. It is likeley that the charging wire has something inbetween the alternator and the battery. One possibility is the charging wire is hooked up on the coil side of the switch. In this senario the Battery (+) goes to the switch. The other side of the switch goes to the coil (+)/and (at the same time)the alternator. As far as charging goes this will work just fine except for the switch itself. Is is not designet to cut off the charging circuit. The switch is only there to cut the power off to the coil. The coil does not take much power and the switch can handle this no problem. The purpose of shutting the coil off is to remove power from the ignition to stop the engine and to keep the coil from draining the battery (since the engine is not running keeping the battery charged)
I said all that to get to the problem. If the charging wire is on the wrong side of the switch. When you turn off the switch you have disonnected the battery from the charging ciruit and the coil. The alternator is still able to provide power to the coil directy and the engine will continue to run untill it slows down enough that the alternator looses ability to put out power. Or you could take the wire off the alternator and accomplish the same thing.....lol.
I know what you are thinking!....THE OTHER SWITCH....that must be what it was for....to turn off the alternator. This would work but is not advisable. It is never good to switch on and off the charging circuit. Expecially under load. It can damage the regulator and or the alternator itself. Its better to let it go straight to the battery. This brings me to the next problem. The battery dying. With the switch turned off you should not have any drain on the battery. There may have a damaged alternator/regulator. If you have been stoping the engine by removing the charging wire, there could be some damage to the regulator/alternator causing it to drain the battery. I learned this the hard way. It's not supposto happen but it has.
Are you asleep?.....
I'll be glad to bore you more if you need me to. I'm sure someone else may have some (hopefully) shorter advise.
Good Luck. D
RockyMO
04-25-2007 04:39:10
Sounds like a classic problem with some 12 volt conversions. The alternator feeds back voltage to the engine not allowing the engine to shut off. Solutions are to install a diode to prevent the back feed to the ignition or install a different ignition switch with an accessory position. I can not see how your tractor is wired, but if you would like a different wiring diagram I should be able to find one for you.
RockyMO
1942 Ford 2N
1953 Ferguson TO 30
Massey Ferguson 2135
Oliver OC3
