TO-30 CARBURETOR
guyeli
04-23-2007 16:50:05
Am planning on rebuilding my carb on my 1952 TO-30,however,after removing my carb I noticed on the bottom near the carb drainage screw what appears to be a model # for my carb.It reads 10A 355.My manual indicates it should be a TSX458.Is it possible I have the wrong carb?.my carb is a MARVEL SCHEBLER,but maybe I,m looking at the # in the wrong place.Is the model # stamped elsewhere on the carb?
rweaver
04-25-2007 14:57:02
 Re: TO-30 CARBURETOR in reply to guyeli, 04-23-2007 16:50:05
If you"re wondering about the rebuild kits, the TO-20 and 30 NAPA kits are the same, even though the MS part number may be different.
Dan S (NY)
04-24-2007 09:20:41
third party image
Here is where it should be.
Bill - SC
04-23-2007 17:08:16
I believe that the carb model # is stamped in the body on a flat area above and below the the end of the choke shaft. I believe the number you listed is most likely a casting number.
