TO 20 Radiator
Dennis Randall
04-22-2007 16:16:11
My radaitor needs re-built or replaced, any comment on the replacement radaitors available. are they as good as the original?
monty lewis
05-19-2007 20:58:59
 Re: TO 20 Radiator in reply to Dennis Randall, 04-22-2007 16:16:11
Try TractorRadiators.com
They will have one plus at a good price.
phil(va)
04-23-2007 10:02:20
The originals are better made than the thin China made new ones. If a good repair shop can fix it properly, that's what I'd do. Talk to them first and make sure. If they look at it and balk, then you may have to buy a new one.
Fergie Fan
04-23-2007 08:43:56
Still got the original rad on my Fergie, due for another trip to the rad shop, they seem to be able to fix it so far.
mike a. tenn.
04-23-2007 06:22:27
i had to replace my radiator. got one thru agco and it worked fine. bhe careful if you decide to get your original one redone. there's radiator repair and then there's re-coring. a lot of places "repair" a radiator but pinching off and soldering up the leaking tube. this is not good for the TO-20, as the major cause of cracked blocks is overheating. by piching off a tube you reduce the cooling capacity of the radiator. recoring replaces all the tubes and fins. make sure if you get yours re-done that this is what they do.
Bruce(OR)
04-23-2007 00:26:16
Look in the parts section and you should find a radiator at $160 new.
Chris M (tx)
04-22-2007 19:25:36
I don't know the answer to your question. But a good readiator shop worth it's salt should be able to repair a leak and flush it out, for a reasonable amount. I had this done on a Porsche car radiator that was too expensive to replace it.
Is a TO20 radiator available? What does that cost? Are there radiator shops in your area?
Bob (Aust)
04-23-2007 03:33:57
 Re: TO 20 Radiator in reply to Chris M (tx) , 04-22-2007 19:25:36
Different beast I know, but an old radiator guy here in Australia who overhauled my TEA20 radiator told me to always repair the original radiator if possible. It was made by Coventry Radiator & Pressworks Ltd, one of the best radiators ever built and twice the weight of modern replacements.
The overhaul cost was slightly less than a modern replacement radiator.
I would guess something similar may be the case in the USA?
