Where to get timing chain and weights for TEA-20
BuddyP
04-17-2007 08:03:35
Where can I get a timing chain and weights for a TEA-20?
Thanks!
John(UK)
04-19-2007 08:37:02
 Re: Where to get timing chain and weights for TEA- in reply to BuddyP, 04-17-2007 08:03:35
You can get those parts from this site (YTMAG) or from a Sparex dealer. The timing chain is S61909 and the governor weight plate is S42423, the Cup and Shaft in the middle which gets damaged is S42421, the oil seal (which cracks with age and heat) is S42195, the gasket to the block plate is S42487. The oil seal and gasket will need changing You will probably find that the governor will need resetting, if you need that information email me at:- [email protected] to locate your nearest Sparex dealer, email [email protected] for USA or [email protected] for Canada, don't forget to tell them your location, they only supply through dealers, not direct.
cdmn
04-17-2007 20:42:45
The chain and gasket and crank seal are available at the AGCO Massey dealers. Tell them it's the same as the European MF35. The governor has to be bought through the aftermarket. They are made in Australia and warehoused in San Francisco.
John(UK)
04-19-2007 08:36:04
 Re: Where to get timing chain and weights for TEA- in reply to cdmn, 04-17-2007 20:42:45
