solenoid for starter
charles hess
04-17-2007 06:19:55
Friend has a Ferguson an needs A Solenoid for a Lucas starter-25519d.Would appreciate an info or help.
John(UK)
04-19-2007 08:48:13
 Re: solenoid for starter in reply to charles hess, 04-17-2007 06:19:55
The starter switch is available from a Sparex dealer or from this site(YTMAG) only if you are in USA. The Sparex part Number is S42538.
To locate your nearest Sparex dealer contact [email protected] for USA or [email protected] for Canada. Don't forget to tell them your location. When you remove the old switch be careful not to drop the operating rod, tie some string around it before you detach it from the switch. You will need to adjust the switch when you fit it, use a lamp across the terminals to make sure that the switch closes and lights the lamp when you press the gear lever in start position if you don't it will burn the contacts.
charles hess
04-19-2007 10:23:35
 Re: solenoid for starter in reply to John(UK), 04-19-2007 08:48:13
Thanks John. I will check site an pass on info althoigh i think he is changing starter.
John(UK)
04-19-2007 11:20:41
 Re: solenoid for starter in reply to charles hess, 04-19-2007 10:23:35
Why would he change the starter, does he know it is u/s. He should check the switch first if there is any doubt about it, otherwise it starts getting expensive.
charles hess
04-19-2007 17:19:32
 Re: solenoid for starter in reply to John(UK), 04-19-2007 11:20:41
I took spartex phone no to him an he is going to pass info on to gentelman who presently has his starter.When i looked at web site it says they are a wholesaler of parts. Good part is they are located in our home state Ohio. Idid not see starter so am not sure what is wrong .Many times you can take solenoid apart an clean parts an turn 1 of contacts an have a good as new solenoid.Apreciate your input. Charlie
Jerry/MT
04-17-2007 17:18:10
It would help to know the Ferguson model. Nonetheless, try the parts folks at the left of this page or www.sparexusa.com
charles hess
04-17-2007 18:22:37
 Re: solenoid for starter in reply to Jerry/MT, 04-17-2007 17:18:10
It is a small t-20 an i did print an give web site to him an he talked to them as i left. Gave him whole list of parts. First time i looked at this post an thank you for response.
