Transmission vent plugs in T035
LanceJ
04-16-2007 14:38:35
Hey guys, I have another question about my 1955 T035. Is this tractor equipped with vent tubes or plugs for the transmission/rear end? In my job as a mechanic, I know that when a vent plug or tube on a transmission or differential gets clogged the pressure causes seals and gaskets to leak. There is a plug of some sort in front of the steering column on the transmission. It looks like it has a metal check ball in the bottom of it, this plug certainly doesn't allow air to pass through it easily.
Paul in AZ
04-16-2007 20:41:37
 Re: Transmission vent plugs in T035 in reply to LanceJ, 04-16-2007 14:38:35
The neutral starter switch has nothing to do with venting. If your lift cover has a vent, it will be on the top left side of the hyrdaulic lift cover, in an indentation just a few inches back from the front. It is called a breather assembly.
Dean
04-16-2007 15:22:40
Lance:
I believe the device that you are referring to is the neutral safety switch. If wired and functioning this prevents starting the engine unless the range selector is in neutral.
Dean
