Don,t Know about my tractor
Hunting
04-15-2007 17:41:23
I have and old to-20 and i changed the steering wheel and didn't get the tag of of it Is there any other way to find out year of tractor and also did these old tractor come standard with a front end loader
mike a. tenn.
04-16-2007 02:35:48
 Re: Don,t Know about my tractor in reply to Hunting , 04-15-2007 17:41:23
hunting...you said you changed the steering wheel but didn't get the tag off it. maybe i'm misunderstanding what you are saying, but the data tag with your serial number should be on the instrument panel next to the steering column...not on the steering wheel. are you saying you changed the instrument panel also?
Krout
04-15-2007 20:47:47
My TO30 has a custom made loader. If that would also work for a 20 I'll send you pictures. Anyone know?
Daniel Collings
04-15-2007 21:04:26
 Re: Don,t Know about my tractor in reply to Krout, 04-15-2007 20:47:47
Id like the pictures if you don't mind.
[email protected]
Thanks
Jeff-oh
04-15-2007 18:50:21
Loaders are never standard items. They were an option though.
Daniel Collings
04-15-2007 19:44:58
 Re: Don,t Know about my tractor (loaders) in reply to Jeff-oh, 04-15-2007 18:50:21
Jeff
I had assumed that there weren't any loaders offered as options and have been looking at designing one myself. Do you know anyone that might have pictures or anyone that might actually have one to look at? Also would you aware of any aftermarket loaders that can be used or adapted?
Daniel(TN)
Jeff-oh
04-17-2007 13:09:26
 Re: Don,t Know about my tractor (loaders) in reply to Daniel Collings, 04-15-2007 19:44:58
third party image
There was a loafing shead loader available. It went by the id number L-UO-20.
I attached an image of the manual I hope it comes through.
These loaders were relatively light weight. Made as Manure loaders not gravel.
Daniel Collings
04-19-2007 19:01:55
 Re: Don,t Know about my tractor (loaders) in reply to Jeff-oh, 04-17-2007 13:09:26
Thanks for the picture and the info.
Daniel Collings
04-16-2007 06:55:50
As usual i found part of the information i was looking for by reading. I found the refrence to the Wagner loader. I am still curious about aftermarket or other loaders that might work.
impcon
04-17-2007 13:28:01
 Re: Don,t Know about my tractor (loaders) in reply to Daniel Collings, 04-16-2007 06:55:50
I have a 1953 TEA that has a Scout loader and backhoe attached to it. The loader and hoe are made by Shawnee in the U.S. but I have not been able to find any history on that company. I can emaill you some pictures if you wish. I have the loader off the tractor right now and I am preparing to remove the hoe so as to make it easier to move the tractor around while I work on the engine which seems to be partially frozen. That is to say, it will turn somewhat but then stops. I am soaking the cylinders with ATF right now in hopes of freeing it up without pulling the head. *sigh* Some things have just come up and I do not know when I will be able to get back at the tractor but I do hope to get back at it soon. Gary
