O ring piston
Robert in Ky
04-10-2007 03:35:36
can someone tell me the part# for the O ring type piston to replace the steel ring piston in a TO20 ferguson? thanks
John (UK)
04-10-2007 09:05:55
 Re: O ring piston in reply to Robert in Ky, 04-10-2007 03:35:36
Ferguson didn't fit an "O" ring type piston to their tractor, they used steel piston rings because they wear longer. You are thinking of the Ford tractor with an "O" ring. Unless the bore of the lift cylinder is unworn the "O" ring will wear rapidly, the steel type ring is a lot more forgiving with the wear factor.
Robert in Ky
04-10-2007 03:38:10
I forgot to say it was for the lift cylinder.
