TO-20 water pressure
John in MS
04-09-2007 14:22:07
In my 1950 TO-20 service manual it states that the coolant system operates at 4 psi. I'm having a little difficulty finding a radiator cap with that rating, and want to know if there is a hazard to using one with a higher rating.
Thanks.
Jerry/MT
04-10-2007 13:37:28
 Re: TO-20 water pressure in reply to John in MS, 04-09-2007 14:22:07
If your cooling system is in reasonable shape, there's no harm in a 7 psi cap. In fact it will give you a higher temperature capbility before the coolant boils. You mention "water" but you should be using a 50/50 mixture of water and antifreeze.
gshadel
04-10-2007 09:26:56
I accidentally ran a 7psi cap on my TO20 for 2-3 years before realizing the error on my ways and getting a 4psi cap. Never had any problems running the 7psi cap. If you have a sound cooling system, it is a non-issue.
I got a 4 psi cap from TSC, it was likely a Tisco supplied cap, so you can probably get one from any Farm & Fleet / TSC type store that sells Tisco parts, or an Agco, or Ford/New Holland dealer. Yes, you can get them from you favorite auto parts place also, I see them pretty regular in Auto Works, Pep Boys, etc.
George
John in MS
04-10-2007 06:05:15
Thanks. I found several sources for the low pressure cap since my posting.
Does anyone have a Napa part number for the To-20 thermostat? I see they have them on the old tractor parts page, so I might just go there to help support them.
steve19438
04-10-2007 16:43:40
 Re: TO-20 water pressure in reply to John in MS, 04-10-2007 06:05:15
where do ya find "old tractor parts" on the NAPA web site????
john [mo]
04-09-2007 20:17:36
i found some info you might be able to use at the parts store. check the first cap listed.
Duner Wi
04-09-2007 19:07:55
Check out a Carquest #33004 . It might be a 4 lb. cap. I have one on my TO 20.
Bob (Aust)
04-09-2007 15:08:33
The recommended radiator cap for my TEA20 is 4 PSI or 7 PSI under heavy load conditions. I too am having problems finding a good quality 4 PSI cap to suit. (Good quality = stainless and copper, not all steel.)
I would think a 7 PSI cap on your TO20 would be OK.
