Oil pressure gauge hookup
Dave
01-16-2001 18:18:33
I have a TEA20 and no manual. The oil pressure gauge is missing and I want to replace it. However, I cannot tell where it plugs into the block. Can anyone help?
MUGU
08-30-2003 09:41:07
 Re: oil pressure gauge hookup in reply to Dave, 01-16-2001 18:18:33
third party image
PLEASE 419 MEN, KEEP OFF, I DON REACH HERE SOOOOO OOO
Joe in NY
01-18-2001 01:52:24
Dave,
The fitting on TEAs is just behind the starter.
You can purshase a manual on this site for the TEA models. It covers all models and configurations of TEAs. The cost is about $60 dollars but the information is invaluable. I got one annd it's the best thing I did. IT manuals don't cover standard engines. When you hook up the guage there is an oil pressure adjustment on the filter. The screw with the locknut. Set between 40-60 PSI
Good luck,
Joe
Svein Arne Jerstad
01-17-2001 12:42:24
Oilmeasure hookup on TEA 20 is placed right behind the starter on the left hand side.
If you look from below ther is a banjofitting, maby replaced by a bolt in an angel of about 45`
Brian in Windsor Ontario
01-17-2001 11:58:14
Dave i have a tea20 that had the problem.Someone had just threaded a bolt in the hole where there is normally a banjo fitting. If no one responds i will check for you this weekend on mine and post back to you . I would tell you now but i dont like saying " i think and im not sure " Brian T.
Phil
01-17-2001 09:54:38
On my TO30 the plug to the block is on the right side just in front of and below the steering box if I recall. Kinda behind the air intake pipe. Not sure if your TEA20 is same or not.
