to-20
GregPatterson
04-08-2007 16:10:18
How do I adjust the clutch on this tractor?
John (UK)
04-09-2007 09:26:21
 Re: to-20 in reply to GregPatterson, 04-08-2007 16:10:18
The adjustment for the Clutch Pedal is 3/8" NOT 3/16" that was a misprint in the manual. This is under the footrest to the top of the pedal.
Jerry/MT
04-08-2007 21:09:19
There is a bolt on the clutch pedal that clamps the pedal to the throw out bearing actuator shaft. You loosen that bolt and then place a drift in the hole in the shaft and adjust the pedal so that the freeplay from the "footpeg" that extends near the rearend of the radius arm is 3/16".
