TO-20 Ferguson trailor hitch
Dan Klingensmit
01-15-2001 09:25:17
Does anybody know where I can get a trailor hitch so that I don't have to use the 3-point to pull a trailor? Any help will be appreciated.
stevie-b
01-17-2001 08:17:52
 Re: TO-20 Ferguson trailor hitch in reply to Dan Klingensmith, 01-15-2001 09:25:17
Dan, You can also get or have made a pair of hich arms and a cross drawbar to hitch a pull type implement to.
I also have a hitch I can bolt to the tractor.
Hope this will help.
I have a TO-30
ZANE
01-16-2001 18:46:41
If the reason you don't want to use the drawbar to pull the trailer is because you can't regulate the heitht or position of the drawbar I can solve that problem if you will check out the link below.
Daniel Klingensmith
01-17-2001 12:16:03
 Re: Re: TO-20 Ferguson trailor hitch in reply to ZANE, 01-16-2001 18:46:41
its not the position that is the problem. The problem is if you come to a stop the drawbar will swing up and jerk you forward
Craig
01-16-2001 03:01:59
Dan - Any of the Farm and tractor stores carry a swinging drawbar kit that will work on your Ferguson. I bought one for a Ford 8n and it bolted right up to my TO-20. I now pull trailers without using the 3 point.
Craig
