PLOWING WITH TO-20
Frank Biscardi
01-13-2001 16:11:58
I tried plowing for my first time today. I couldn't really get the plow to go deep enough. I shorthened the top link some which seemed to help and I got the plow in about 6-8 inches. Do I just need to continue to shorten the top link or is there someother adjustment? I am using a two bottom (? 14in) plow.It is painted blue. I thought it was a Ford implement, but it says Wird on the side of it.I am busting sod which hasn't been plowed before. It is re Albermarle Virgina red clay
I was really satisfied at how well this little 20 hp tractor pulled that plow.
Thanks
Frank
Plowing in January?
01-14-2001 16:39:00
 Re: PLOWING WITH TO-20 in reply to Frank Biscardi, 01-13-2001 16:11:58
Never heard of anyone plowing in january. I bet that fergy was strainin' pullin' 2-14's in virgin clay.
ZANE
01-14-2001 07:21:12
See my link at the bottom of this post if you want to have position control added to the hydraulic lift on that TO 20.
Plowing with an 8N Ford tractor Posted by ZANE on January 01, 1999 at 06:48:44: In Reply to: plowing with an 8n posted by john alexander on December 31, 1998 at 20:00:53: Attach the plow to the 3 point hitch. Drive the tractor's left rear wheel up on a 6 inch block. use the right hand leveling crank and the top link screw adjustment to level the plow share and the land slide with the ground. Do this on a good level spot or on a level slab of concrete. Pull a string from the back of the land slide to the front of the tractor or futher out in front of the tractor and make a stright line beside the land slide to the front of the tractor.The line should angle slightly to the right front wheel of the tractor about 6 inches more than the left. This is to assure that the plow doesn't try to turn the tractor right when the plow comes in contact with the earth. Think of the plow acting as a rudder would on a boat. The way to adjust the angle of the landslide to the left is to loosen the bolts that hold the drawbar that goes across the plow and attaches to the two lower links and twist it in it's cradle untill the plow is pointing in the right direction.(string pointing to the right at the front of tractor) The plow will have to be raised to let it more easily be moved. Some plows have adjusting bolts that help in turning the plow and in sequering it in position. This is just a premilary adjustment and when in the field it may be necessary to tilt the plow slightly forward by shortening the top link etc. Good luck and let me know how you do. Zane.
To prevent the plow from trying to turn the tractor you need to adjust the draw bar.Think of the plow as the rudder on a boat.If you want the boat to turn left you turn the ruddre left.The same is true of the plow.The drawbar has an offset on the right side with the offset turned down.To turn the plow as a rudder to the left to make the tractor stop turning right when the plow is engauged,loosed the bolt that secure the drawbar to the plow.Turn the drawbar counterclockwise looking at the right end(offset).in order to make the tail of the plow turn to the left.It only takes little to turn the plow tail a lot but do it so that the tail of the plow is moved about 6" to the left.Retighted the bolts that secure the drawbar to the plow.
Put the little lever that is under the seat in the down (draft control position) Move the lift lever till the plow drops to the ground.Advance the tractor and gradually move the lever more down till the plow is at the depth you wish to plow and then set the lever at this point with the stop to make it stay there.
A flat bottom plow should be set so that when the plow opens the furrow the bottom of the furrow will be flat.Hence"flat bottom plow"!!If the plow will not go in the ground with the plow set flat,get new plow points.
When using a 14" flat bottom plow the distance from the inside edge of the right rear wheel should be 14" from the most forward point of the first plow.Or 14" from the landside of the first plow to the inside of the RR tire.
The tires of the tractor should have water in them or either wheel weights.
Ray,IN
01-13-2001 20:19:27
Sounds like you are doing everything right. I have the about the same results in this so. IN clay. The master control spring (top link attachment point)will limit the rotating force of the plow and release hyd. oil pressure when encountering an obstruction or excessive force, allowing the plow to rise enough to limit the front end rearing, or damage to the tractor. Shortening the top link may improve results though. If shortened too much, the plow will bury itself and stop the tractor. The O&M manual says to plow in second gear, but I think it's too fast for small areas. Have fun!!
