TWO HANDLE TOUCH CONTROL ON FERGUSON
ZANE
03-30-2007 06:16:56
Explain to me how to use draft control on a TO 30 Ferguson tractor that has two handles on the quadrant for the lift. One is position I assume and the other is draft?????
Zane
John (UK)
03-30-2007 07:13:05
 Re: TWO HANDLE TOUCH CONTROL ON FERGUSON in reply to ZANE, 03-30-2007 06:16:56
Sounds like you have a TO35 Zane, I have sent you the Information you asked for.....John
Dave Stock
04-01-2007 18:45:07
 Re: TWO HANDLE TOUCH CONTROL ON FERGUSON in reply to John (UK), 03-30-2007 07:13:05
If it is not to much bother I would like a copy of what you send out for TO35 draft control.
John (UK)
04-02-2007 08:16:10
 Re: TWO HANDLE TOUCH CONTROL ON FERGUSON in reply to Dave Stock, 04-01-2007 18:45:07
That is no problem at all Dave to send it to you but you need to email me at:-
fergusontractors(at)tiscali.co.uk
and ask me on there so I will have an email address for you to send it to...John
mike a. tenn.
03-30-2007 07:42:40
ya...i'm figuring he's got a 35 also John...that's why i asked for the SN's.
mike a. tenn.
03-30-2007 07:03:27
zane...first of all, if you have both position and control levers, i don't think you have a to-30. i'm pretty sure the all to-30's have only one control lever like the to-20. how 'bout we confirm what tractor you have first and go fro0m there?. is htere a data plate on the instrument panel near the steering column? if so...give us the serial number from it. there is also a engine id plate on the left side of the engine block just below the head about midway from front to back. post the info off that plate too if you have it.
-mike
mike a. tenn.
03-30-2007 07:05:06
 oops! i meant to say.... in reply to mike a. tenn., 03-30-2007 07:03:27
"if you have both the position and the draft control levers"...
