TO20 TE20 Axles
Harrison in Dal
03-29-2007 15:13:09
Will an axle from a TE20 work on a TO20?
John (UK)
03-30-2007 07:19:17
 Re: TO20 TE20 Axles in reply to Harrison in Dallas, 03-29-2007 15:13:09
Yes they will fit, the difference between the two axles is that the later one has a heavier Bush for the Pivot pin, as long as you use the correct Pin it will fit. Check the diameter of the hole for the bush, it is bigger on the later type, it is the same as the early type 35 too.
Harrison in Dallas
03-30-2007 09:04:03
 Re: TO20 TE20 Axles in reply to John (UK), 03-30-2007 07:19:17
Thanks for the replies. Appreciate your time.
John(Ont)
03-30-2007 05:15:28
They are two different part numbers. Don't know what the difference is.
