TO-20 crankshaft question
Steve Moyer
03-29-2007 05:57:31
I did a valve job on my to-20 last summer and now need to do the pistons, rings and sleeves. How do I judge weather I need to have the crankshaft done or not. The engine runs well but burns oil, and does not make any exesive or unusual noise.
Jerrycpp(WA)
03-29-2007 08:19:15
 Re: TO-20 crankshaft question in reply to Steve Moyer, 03-29-2007 05:57:31
Keep in mind that a worn crank does not necessarily make noise. It can, however, cause oil useage. This happens because when there is excess clearance between the bearing and the crank, more oil is splashed onto the cylinder walls, and worn oil-control rings can't keep it all out of the combustion chamber.
Brian Derry
03-29-2007 06:14:17
You should not have to do anything with the crank expet put new bearing the piston to contect to the crank and you should be just fine. If u hve any question Feel free to email me and i will answer any questions u have.I work for joe Busch ag repair in boone iowa.Thanks brian
