Lift/Hydralic pump re-install
Mick74
03-26-2007 04:28:25
Hey fellas, I'm getting close to re-installing the lift, and pump for the hydralics on my 30 after taking things apart for a good cleaning. Is there anything I should know, any tricks of the trade, or pit falls apon re-installing? You guys have been a great help to me, as I am doing all this stuff for the first time. Thanks for the advice.
Jim W
03-26-2007 13:46:12
 Re: Lift/Hydralic pump re-install in reply to Mick74, 03-26-2007 04:28:25
When the bolts are just finger tight on the pump I have found it helps to rotate the pto shaft by hand, to ensure it doesn't bind i.e. there is a little play in the pump so you can re-position it very slightly to optimize.
Jim W
John (UK)
03-26-2007 13:17:29
Make sure that the Draft Control Spring is set correctly before you refit the top cover and the Control Quadrant when you have refitted it.
