TO20 valve chamber gasket
RNeill
03-21-2007 07:36:47
I have a blown valve chamber gasket on the right side of my TO20"s hydraulic lift pump. Does anyone know if I can replace this through the inspection port or will I have to remove the pump to accomplish this? Any help will be appreciated.
John (TR)
03-21-2007 16:28:52
 Re: TO20 valve chamber gasket in reply to RNeill, 03-21-2007 07:36:47
How did you come to diagnose it?
I've pulled the inspection cover before to observe the lift piston but not the pump
RNeill
03-22-2007 04:54:25
 Re: TO20 valve chamber gasket in reply to John (TR), 03-21-2007 16:28:52
Pulled inspection covers and observed turbulence in the pool behind the pump. Originally I thought relief valve and I took care of that but when all was back together the turbulence was still there. I felt around a bit and found the leak coming from between the pump body and the valve chamber on the right side of the tractor.
John (UK)
03-21-2007 09:07:23
You will have to remove the Pump and replace both gaskets. If you need the information for doing this, email me at:-
fergusontractors(at)tiscali.co.uk
John
