TO 20 DISTRIBUTOR
mike iowa
03-21-2007 07:22:01
My mechanic grabbed ahold of the distributor and pulled it out of the block with ease-then set it back in---we work on the tractor about every 4 or 5 th day, this is 3rd day in cycle, it finally occured to me that the distributor probably has to be reseated in a certain position in order to fire properly--also, was wondering if there is a screw missing that holds the distributor in place.
-- feedback appreciated
pojo
03-21-2007 12:50:28
 Re: TO 20 DISTRIBUTOR in reply to mike iowa, 03-21-2007 07:22:01
I am not sure of the distributor type on a to-20, but a to-30 has a single bolt hold down secureing the distributor in place with a clamping ring. You can not remove the distributor without loosening the clamp. This also keeps the distributor from rotating out of time. If a distributor is re-installed even one tooth off on the gear drive, it may not run at all, and you will never get the correct timing.
mikeiowa
03-22-2007 05:20:52
 Re: TO 20 DISTRIBUTOR in reply to pojo, 03-21-2007 12:50:28
thanks for the info on the "one tooth"-wish i had the money to just turn it over to a real mechanic but at this point i do not. I have the manuels so i recon i will have to get busy reading up on it.
mike a. tenn.
03-22-2007 05:27:04
 Re: TO 20 DISTRIBUTOR in reply to mikeiowa, 03-22-2007 05:20:52
mike...you don't need a "real mechanic" this is not a big deal. are you still having problems? if so describe what you've done or what you still have questions about...we'll get 'er solved for ya. that's what this forum is for.
-mike
mikeiowa
03-22-2007 05:41:40
 Re: TO 20 DISTRIBUTOR in reply to mike a. tenn., 03-22-2007 05:27:04
thanks mike, that is a confidence booster--i havent beared down to get it done, am about to let the "mechanic" move on to other endeavors unless He proves out in the next "mechanic" session.
---i bought a 3 manuel set, now i know by way of this site the manuels are correct for the TO20-so i just need to get down to business and get er done.
thanks again- i surely will make use of this site-man what a great tool to have--surely the best tool i've ever had.
thanks again
