T0 30 Brakes
RockyMO
03-20-2007 18:22:22
Are the brakes on the T0 30's the same as a 9N Ford? Complete with the same leaky axle seals, and if so will the sure seals fit them? Also, what would be the best shop manual to purchase for one of these?
Thanks, Rocky in MO
gshadel
03-21-2007 12:45:07
 Re: T0 30 Brakes in reply to RockyMO, 03-20-2007 18:22:22
The TO30 has inner/outer seals, like a 8N & the TO-20 has an outer seal only, like the 9N. The TO-20 & 9N are the usual candidates for sure seals. I think the TO-30 is best serviced with standard replacement seals from the dealer.... ain't that right?
George
Irv (Ia)
03-21-2007 06:07:29
The TO-30 already has inner seals from the factory
Bob in AZ
03-20-2007 23:09:59
The Sure Seals are the same as a 9N . Part # is Tisco SS92. It comes 2 seals in the kit - enough to do both sides . Usually around 10 bucks
The brake shoes I"m not sure if they are the same as the Ford . Somebody here will know . They usually go for around 55 bucks for the correct ones .
