TO35 Engine Siezed
Dean Logan Ohio
03-20-2007 17:58:31
HELP !!!I have a "59 TO35 Deluxe with a Z134 gas engine. Yesterday,as I atempted to start the engine She backfired and then just clicked the starter.Since I was parked on the gravel drive with a downgrade I tried a rolling start but just skidded the rear wheels. I also tried to turn the engine by the crank pulley but with no results.I had started earlier in the day with no problem and only had driven a short distance to bring a small trailer to the garage to work on.Does anyone have any idea what could have hapened? What should I check 1st?I did pull the plugs but found nothing.I'm hoping for the best but expecting the worse.
Gregg/Ohio
03-20-2007 20:56:45
 Re: TO35 Engine Siezed in reply to Dean Logan Ohio, 03-20-2007 17:58:31
Quote:("She backfired and then just clicked the starter") Check for Starter Failure,and or Starter Housing lockup,in Flywheel.
dean logan OH
03-21-2007 16:02:23
 Re: TO35 Engine Siezed in reply to Gregg/Ohio, 03-20-2007 20:56:45
Good call guys. I pulled the starter and the nose was broken off. I was able to find a large piece with bushing after removing the inspection plate under the clutch. I don't know if that was the only piece till I go back to the local re-build shop to check fit with the broken one. The engine turns freely now and I havn't been able to find any more pieces.
Thanks for all the help.
Dean
gshadel
03-21-2007 12:39:29
I agree with Gregg, try to pull your starter out. I've seen more than a couple posts where the starter jambs-up on a flywheel with a ring gear kicking off the flywheel.
RockyMO
03-20-2007 18:24:35
Can you crank it over by hand with the spark plugs removed and trans in neutral with the clutch depressed?
Rocky in MO
Dean Logan Oh
03-20-2007 18:42:14
 Re: TO35 Engine Siezed in reply to RockyMO, 03-20-2007 18:24:35
I did pull the plugs to check if maybe a jug full of gas.Since the plugs were dry I didn"t try turning it over with them out.Was that what you were thinking? I"ll stil give that a try.
Dean
