Rear lift problems TO-30
Dave PA.
01-08-2001 11:43:30
Recently purchased a to-30 from a relative, it has a front loader and everything for the most part in decent working condition. The rear lift works in both operating positions untill weight (as little as 50 pounds is added)and then will not raise. Fluid level seems to be good and the loader works without any signs of problems.. any imput greatly appreciated Dave in PA.
ZANE
01-14-2001 07:36:10
 Re: rear lift problems TO-30 in reply to Dave PA., 01-08-2001 11:43:30
The 9N lift has no position control.To maintain the lift at a given position the hand must constantly be on the control lever to continually re adjust. I can fix that for you if you will Email me at [email protected] or see the link below.
The most common places to leak on the lift is the piston rings and the pressure relief valve.
In order to determine where the lift is leaking you should remove the right hand inspection plate that holds the dip stick for the lift oil.If oil runs out when this cover is removed it has too much oil in it and letting it run out is ok.
Start the tractor with a load on the lift arms such as a rotary cutter etc. raise the lift and observe inside the lift to see where the oil is leaking down.If the piston rings are leaking their will be a pretty good stream of oil coming out the end of the ram cylinder. If just a few drops this is ok.
Observe the oil in the resorvoir and if you see the oil swirling around the relief valve is probably leaking.It is the gadget that is screwed into the back of the hydralic pump just under the pto shaft.It will be under the oil and feels something like a spark plug.
If before starting the tractor you will put your hand into the oil and locate the relief valve you can reach in and put one finger over the end of the relief valve and determine if it is leaking after the tractor has again been started. DON'T MAKE THE MISTAKE OF PUTING A FINGER IN THE PUMP MECHANISM!!!!
If however you don't see a signifacant leak from the top you can assume that the relief valve is leaking and simply replace it with a new one and thereby prvent the possible loss of a finger or two.
I;ve never tried it but I�ve read that you can drain enough oil from the lift reservoir to uncover the relief valve and see if it is leaking instead of using the obviously dangerous finger feel thing I described.
There could also be a blown gasket somewhere in the upper portion of the lift but if so you will see a lot of oil coming down from the top and then it�s just a case of taking the cover off and finding the culprit.
Be sure to release the control rods from the control valve T on the pump before trying to remove the lift cover. To fail to do so will result in a broken lift control valve stem.
Zane in Alabama.
If you should be having trouble with the lift not going down when the lever is moved to the down position I would suggest that while the inspection plate is off on the side of the lift housing you reach in and manually push the two levers that go into the oil in the reservoir and are connected to the control valve. The control valve sometimes sticks in the up position. If you should find that you can make it go down by pushing toward the front of the tractor internally on the control rods then you should drain the lift and pour about 5 gallons of clean kerosene through the lift with the drain open. It is best to pour it directly into the inspection hole. Let the kerosene that drains out sit for about 15 minutes and pour it through again leaving the portion that is in the bottom of the container to be discarded. This should have the residue in it that may have been causing the control valve to stick when it was carried into the control valve.
You should also inspect the spring that is connected between the front end of the ram cylinder of the lift to the knee portion of the control rods that go from the linkage at the top to the control valve in the bottom of the pump. This spring sometimes looses it tension from age and usage and must have enough tension on it to pull the control valve out when the lever is moved to the down position.
Ray,IN
01-08-2001 19:14:44
Look just below the dipstick and you'll see a acorn type nut with a lock nut behind it. loosen the lock nut and tighten the acorn nut 1 turn. If this improves the lift, the relief valve was leaking. If there is no change, return the acorn nut to it's original position. My tractor did this and the nut had worked loose with the lock nut following it, so nothing appeared loose. Like TomB said, look inside; with the control in the raised position, if you see fluid falling down from the top you have a leak in the hyd. system.
Tom B.
01-08-2001 14:24:32
Could be any number of things.
Water in hyd fluid - worn out/incorrect fluid.
Worn Lift cylinder or lift cyl. piston/rings.
Blown gasket at high pressure tube at lift cyl. plate. Bad relief valve.
Hyd pump rebuild.
The only way to find out is to take the side plate off at the PTO lever and have a look inside.
Theres a whole bunch of info on archives- do a search them or on the Ford N board..
I have a page I can email you on things to look for if you would like.
Just did my TE20 and knew nothing about it before I started. Keep asking questions - they ain't that complicated.
Tom B
TOpeka Ks.
