TO-30 Radius Rod
Roger Wolf
03-18-2007 09:43:33
Are the radius rods on a TO-20 the same size as on a TO-30? I have a TO-30 that has one that has been broken a couple of times, but the other is in good shape. I have a chance to purchase a good used one from a TO-20. I am hoping there is no difference. Can anyone help?
John (UK)
03-19-2007 13:21:59
 Re: TO-30 Radius Rod in reply to Roger Wolf, 03-18-2007 09:43:33
Do you know why it has broken, they don't usually give trouble like that. Check the Front Axle Pivot Pin and Bush, if that is worn it loads up the Radius Rods but it usually bends them up-wards in the middle.
Irv ( Ia)
03-18-2007 18:46:33
Yep, same one.
C.T in Va.
03-18-2007 16:56:27
I just betcha it will be the same.The only difference that i am aware of in the two tractors is the engine size.And i betcha somebody on here can give you a more direct answer.
