TO-30 Thermostat
wbeaz
03-18-2007 09:04:13
I was wondering where the thermostat is located. Is it supposed to be in the upper radiator hose? Would not having a thermostat cause coolant to leak into the oil pan due to condensation or such?
Jerry/MT
03-18-2007 18:37:28
 Re: TO-30 Thermostat in reply to wbeaz, 03-18-2007 09:04:13
Not having a thermostat will keep the engine from reaching the proper operating temperature which could mean that all the condensate and water from the combustion process in the blowby gases doesn't get expelled by the breather tube. Make sure that you have coolant in the oil and not condensate before you "tear into it".
A $15 thermostat is an easier fix than tearing in to the engine and finding nothing amiss.
overunder1
03-18-2007 18:00:04
Take a look in the archives for tips on this one. I had a great time figuring that question out as well until others on this board came to my rescue. The thermostat goes in the upper radiator hose and be sure to install it facing the right way otherwise you will overheat the block. However, if you have antifreeze in your oil pan I am with Mike and hope you only have a blown head gasket.
-Lee
wbeaz
03-18-2007 15:39:07
Thanks mike a. tenn. That just confirms my original suspicons. I was just fishing for an easy fix, but I'll just bite the bullet and open her up. Thanks agian, everyone on this site has been wonderful in helping an amatuer.
mike a. tenn.
03-18-2007 15:18:36
i see no one has the heart to tell you that the coolant in your oil pan probably doesn't have anything to do with your thermostat or condensation. if you have actual "coolant" in your oil, it's most likely either leaking in around your head gasket somewhere, or thru a crack in the head or block. we'll keep our fingers crossed for you, that it's the head gasket.
-mike
-mike
