TO-30 Spark Plugs
wbeaz
03-18-2007 08:54:54
I bought a 6 volt tune-up kit for my TO-30 when I first got it, and upon further investigation I found out it had been upgraded with a 12 volt system. Can I still use the spark plugs from the 6 volt kit on my tractor? I know the coil won"t work. What about the distributor, wires, or points?
phil(va)
03-18-2007 19:24:04
 Re: TO-30 Spark Plugs in reply to wbeaz, 03-18-2007 08:54:54
The Autolite 386 is the standard plug. I like the Autolite 3116 plugs myself. Both work fine.
Jim in OH
03-18-2007 10:01:03
Distributor, cap, rotor, wires, points, condensor, sparkplugs... no difference... JIm
TexMac
03-18-2007 13:34:26
 Re: TO-30 Spark Plugs in reply to Jim in OH, 03-18-2007 10:01:03
Only thing to add is beware of new, replacement condensers that are "Hechoed in Mexico". If the tractor cranks and runs a few seconds and dies again, the condenser could be shorting internally. The replacements seem to have marginal insulation between the plates and are not self healing if using a 6V coil and a dropping resistor. Apparently the condenser sees the full 12 volts until the resistor heats. I finally threw in the towel and switched over to 1974 Toyota truck condensers (bought out the local dealer"s stock). Never had a problem since. Current one has been installed for 4 years.
Rest of the parts, as stated, will never know the difference between 6 and 12 volts.
