PTO clutch
Robert in Ky
03-16-2007 16:36:47
Ihave A TO20 that has had a clutch put on the PTO shaft coming out of the tractor and I can wobble it from side to side I wouldnt think that it should but I wanted to be sure, and if its not suppose to have play in it how do I fix it?thanks alot.
Ed H-OH
03-17-2007 05:13:33
 Re: PTO clutch in reply to Robert in Ky, 03-16-2007 16:36:47
Robert, Hello, Mine works side to side about 1/8 of an inch, i think it done that when i put it on new and i beleave it is normal). If the wear is excessive (1/4 inch or more it may be worn out and in danger of coming apart. Thats called an override clutch , to keep the implement from pushing the tractor with it's momentum ( bush hog etc.) I stops reverse torque on the shaft by slipping and clicking like a rachet. They work well and last for years if you pump it full of grease before you use it. -ed
