ROLL BAR
Frank Biscardi
01-06-2001 17:24:38
Well I have a real pretty T0-20. If I get a few dings hammereed out and get it painted it could be a show tractor. However I bought it to work and I need to be safe with it. I would really like to put a roll barr on it but am worried about the esthetics. I guess getting blood all over it won't much help its looks either.I have been suprised at how fast one can get in trouble with a tractor. Has anybody out there ever welded/ bolted a roll bar on a TO-20 and if so how?
Thanks
Frank
Jon in Aus
01-18-2001 17:20:20
 Re: ROLL BAR in reply to Frank Biscardi, 01-06-2001 17:24:38
Guys, in Australia there are laws which basically mean that you HAVE to have a roll bar on your tractor. It doesn't look that bad at all. My FE35 is not pretty, its a work horse, so I'm glad to have the protection anyway on my slopes.
Something that everyone seems to have forgotten. There have been two deaths last year where the tractor has flipped on its rear axle, presumably they had connected their load above the draw bar, but it does not sound like a nice way to go!
Because just about every tractor in Australia has a Roll Bar you can imagine the that the price is reasonable - mine cost me $500 AUS.
Bareco - www.bareco.com.au I think have a rollbar which is generic, they also have a canopy which connect to it too. Worth looking at since $500 Australian is about $25 US ;-) and import costs could be reasonable.
Jon
Ray,IN
01-10-2001 19:56:28
I solved this problem by setting the wheels out, looks like a big spider from a distance, but the wheel width is greater than the overall height of the tractor. The bonus- didn't cost anything but time, and the tractor will slide sideways but doesn't feel tippy on the 45 deg. slope of the dam.
Frank Biscardi
01-11-2001 03:27:11
 Re: Re: ROLL BAR in reply to Ray,IN, 01-10-2001 19:56:28
Ray,
I had thought of spacing out the front tires as well. However, I read that that can put stress on something in the front end (bearings?). Then again I don't think I use the tractor more then 50 hours a year so maybe that is a good thing to do not withstanding.
Frank
Ray,IN
01-11-2001 20:45:12
 Re: Re: Re: ROLL BAR in reply to Frank Biscardi, 01-11-2001 03:27:11
The front wheel bearing strain/stress only enters at the 76"> settings. Front wheel max. width is 80" at tire center. Rear wheel max. width is 76" at tire center.
JR
01-06-2001 20:49:54
I am going to put a rollbar on my Farmal Super C. Bolt it directly to the back axle,never to the fenders. You can't use to big of tubing, I'd use at least 3". A lot of people say you shouldn't make your own rollbar, maybe you could copy a design from a certified factory ROPS. A certified ROPS for most old tractors costs about $600. Forget that. If you ask me a rollbar by itself looks stupid, so I am also going to install a canopy to keep me in the shade and a little bit drier. If you aren't good with a welder get someone who is to make the ROPS for you. The Ferguson TO-20,30's and Ford N's are lightweight,therefore easy to flip.
Clark
01-09-2001 06:57:02
 Re: Re: ROLL BAR in reply to JR, 01-06-2001 20:49:54
Why is it that you don't see many roll bars or cages on fergies or N's? I've seen hundreds of pictures of these tractors on the net, and have maybe seen a couple with roll bars. Is it just not cool or what? I've been thinking of putting one on my TE20, as I have to mow a pretty steep pond dam, no problems yet, but you never know!
Frank Biscardi
01-09-2001 09:59:18
 Re: Re: Re: ROLL BAR in reply to Clark, 01-09-2001 06:57:02
I looked at my tractor today. The only flat surface on the axel is the casting where the fenders mount with two very large bolts. Can I take off the fenders, put two drilled, big (3/4) steel plates on the flat castings to mount the roll bar on and then put the fenders back on with longer bolts that go thru the exsisting holes in the axel, through the plate and thru the fender mounts? This would raise the fenders the thickness of the plate. If I size the plate right the hydraulic levers shouldn't hit any thing. Is this an OK way to do it?
Clark, I don't know why more people dont use roll bars. I guess it spoils the looks of the tractor, but they can be removed for shows/ tractor puls.
Frank
JR
01-09-2001 11:13:58
 Re: Re: Re: Re: ROLL BAR in reply to Frank Biscardi, 01-09-2001 09:59:18
Sounds good to me about how you are going about it? You probaly want to put some thin rubber about 1/8" or less where the metal pieces are joined to the plates on the axle to reduce noise from vibration against the fenders. A lot of rollbars with canopys are very noisy. The little IH 284 that I use sometimes likes to make very loud vibrating noises, especially going at top speed.
