TO 20 12 volt conversion
Ed Lollis
03-14-2007 02:45:46
I see that 12volt conversion kit is available for TO30's but not for TO20's. Can someone explain why not the TO20???Is there a problem mounting belt tendion adjuster on water pump lugs??? Appreciate any help.
Glenn/Calif
03-15-2007 16:51:46
 Re: TO 20 12 volt conversion in reply to Ed Lollis, 03-14-2007 02:45:46
Ed: You might want to look at the items available on EBAY. Search for Universal Alternator Bracket. There are several listed. They run $30-$35. My problem is the high cost of shipping to Calif. There is also a listing for a Delco Generator to Delco Altenator Bracket. I'm not sure of the spacing. I think I will fabricate my own adjustable bracket due to cost of product and shipping. LOL Glenn
John in MS
03-14-2007 13:55:14
I just spent the last several months wrestling with this exact issue, and now know intimately how to deal with the problem. There are a lot of details and I can help you step-by-step off-line if you want so not to clutter up the forum.
John
Ed Lollis
03-15-2007 03:27:29
 Re: TO 20 12 volt conversion in reply to John in MS, 03-14-2007 13:55:14
would really appreciate any help, how can I contact you? Ed
Paul in Ms
03-14-2007 03:41:19
You can take a to-30 kit and make a lower mount. Everything else is the same. For some reason nobody has made a kit for the to-20. I think the lower mount area changed in the early years so there would have to be two mounts in a kit. I might be wrong but it sounds good. This has been adressed many times in the archives.
gshadel
03-14-2007 10:36:41
 Re: TO 20 12 volt conversion in reply to Paul in Ms, 03-14-2007 03:41:19
I think Paul has hit on it, TO-20's have a different mounting bracket than everything else... law of supply & demand...not a lot of demand.
I've seen several 12V TO-20's, they all had home-made brackets.
