TO 20 1950
mike pollet
03-08-2007 13:37:13
Hello --am getting ready to begin fixing or overhauling engine on Our TO 20--a couple years ago, my Father jury rigged the oil pan plug-failed, tractor ran out of oil--they drove it up a smallish hill back tothe barn, then pushed it in, been there ever since. ---Going to try to do the minimum first, never know , with fresh oil, get it unfroze it thats the case, heck it might start up and run ok-(probably not)putting fresh oil in.
two Questions please. 1.) i have a new gasket, do i use gasket seal installing it?
2.) What oil do I use for the crankcase?
Weather is finally breaking, man that was a long january febuary.
thanks
Jerrycpp
03-08-2007 14:06:19
 Re: TO 20 1950 in reply to mike pollet, 03-08-2007 13:37:13
If it's the pan gasket, yes, use sealer. If it's the large rubber gasket where you change the oil filter, do NOT use sealer. Any sealer you use there will act as a lubricant and the gasket will squirt out the side.
mike a. tenn.
03-08-2007 13:46:45
mike...two more questions. which gasket are you talking about...the oil pan gasket? if so, sure! use gasket seal. do you live where it's cold? if so a good multi-grade, 10w 30 will work well for you. if you live where it gets hot like me try a 10 or 15w 40. the manual for a to-20 calls for straight 30w....if you want to go by the manual.
by the way...lots of good knowlege and info about your tractor on the harry ferguson forum on this web-site. click on "show all forums" and scroll down.
-mike
mike a. tenn.
03-08-2007 13:48:34
 Re: TO 20 1950...OOPS! in reply to mike a. tenn., 03-08-2007 13:46:45
...ha! i forgot where i was. you're already IN the fergie forum! sorry mike.
-mike
