Logsplitter, not hydraulic
Jim W
03-08-2007 13:00:24
third party image
Saw this splitter from England but can't find something similar in North America. Was thinking of building one, since my TEA is pretty lame in the hydraulics department, but does anyone know of a source for the screw? I think the frame would be easy enough.
Thanks,
Jim
Make mine a Massey
03-10-2007 16:19:19
 Re: Logsplitter, not hydraulic in reply to Jim W, 03-08-2007 13:00:24
Kind of a screw type splitter, used to see guys selling these units to bolt to the wheel of your truck. Theory was that you jacked up the truck, assuming you didn't have diff lock, remove a wheel, bolt this little nightmare on and split your wood. To me it always seemed too low to the ground and a whole lot more dangerous than splitting wood ever needed to be. Give me a good axe or a hydraulic splitter anyday, if I'm going to handle wood, I prefer to do it standing up.
Barry from Stirling
03-09-2007 16:00:56
Hi jim
Long time no see, how are things with you? A few years ago a guy was at our local fair, he had this item as you show. It was called the Stickler and the guy claimed it would split ANY peice of wood or it was FREE. I have to tell you, all the older guys in the crowd went home and came back with their most knottiest peices of wood. The guy ended up giving away 5 spitters that day. Funny, no one ever heard from this guy again. They do work well on softwood but awful on hardwood. Anywat, stay well Jim,,,,, ,,,Barry
John(Ont)
03-08-2007 16:43:35
Jim: Here is the site for the "Stickler"
Link
John(Ont)
zippy in MI
03-08-2007 16:41:02
 I have used a similar outfit in reply to Jim W, 03-08-2007 13:00:24
I don't have a picture handy, but I bought one from a guy who used it on his Power Wagon. It consisted of the auger screw like you show, but with a hand-made frame to twist against. I also used this on my old Dodge Power Wagon which has a rear PTO shaft.
This works but I found I could just about as easily split the wood with one swing of the awl. Very difficult wood to split like hickory didn't work too well on the auger either. The awl would get very wedged in but the wood wouldn't split...sometimes it just stalled the engine. Then it was very hard to get it off, usually I had to run the PTO in reverse (which you can do on the truck) and unscrew the awl out.
The awl is available from England but no longer in the US as far as I know. The one I got came out of a farm auction and that is where you might find another. I think they are considered a safety hazard although the new UK designed version you show looks safer. But if you get your clothes caught up, you are a dead man. I took my shirt off when I did this and still made my wife sit in the truck to turn it off if anything went wrong.
John(Ont)
03-08-2007 16:36:11
It appears to be an item that was manufactured called a "Stickler". They were made to fit on a PTO and also to bolt onto the wheel of a vehicle. You just jacked up the one wheel to use it. They did not have the frame attached, just the screw and you used the ground or an attached bar to stop the wood from spinning.
Gerald J.
03-08-2007 14:13:36
The number of broken arms and legs with this style have driven the makers underground.
Gerald J.
Jim W
03-08-2007 14:26:42
 Re: Logsplitter, not hydraulic in reply to Gerald J., 03-08-2007 14:13:36
third party image
Is it the fault of the equipment though, or the operators? I have this saw, and people have been quite shocked by it too, but then they turn around and fire up their chainsaws, which are plenty dangerous.
steveormary
03-10-2007 20:31:14
 Re: Logsplitter, not hydraulic in reply to Jim W, 03-08-2007 14:26:42
I have cut alot of wood the way Jim W is doing.
I had a stand alone saw and run it with a flat belt.
steveormary
Andy Moncman
03-08-2007 13:46:21
Jim,
The parts were purchased from Bare Farm Equipment
Rt. 45 Ellsworth Ohio Ph. 330-533-4317
ANDY MONCMAN
03-08-2007 13:21:37
Jim,
My neighbor has one similar to that, the screw is two pieces the larger end is cast and the tip is is harden steel. I used it a couple of times and I broke the tip, he had it attached with roll pins,when I replaced it I used brass shear pins to give it a weak link like a boat prop. If I remember right I bought the parts from Madison supply or Mason supplyin N.E. Ohio. This one looks safer to use, his did not have the table to keep the log from spinning only a bar. I'll check with him later on where we got the parts.
