oil on brakes
J n CO
03-05-2007 12:00:06
Can anyone give me info on either cleaning the grease off of the brake shoes of my TO20 and putting in a seal or finding new shoes and installing a new seal?
John (UK)
03-05-2007 14:18:20
 Re: oil on brakes in reply to J n CO, 03-05-2007 12:00:06
You can't get the oil out of the linings on the brakes you need to reline the brake shoes, you can fit "Sure Seals" as George suggests, that is easiest way. If you need more info about doing this repair, email me at:- fergusontractors(at)tiscali.co.uk
gshadel
03-05-2007 13:49:27
J,
check out my fairly extensive TO-20 website... has a full page on EXACTLY what you asking about.
I've not heard of guys have good sucess cleaning-up oil soaked shoes. They are somewhat porous, soaking in gas, hexane, whatever, is probably not going to give you the best results, but might work good enough for low speed tractor stopping in a pinch. New shoes are ~$50 for both sides either off this web site, Ebay, or other places. Sure seals can be bought off Ebay also, maybe ~$25 total, probably get them from any dealer that handles Tisco parts also. You can replace the original oil seal, instead of sure seals. If you go that route you will need to drill & chisel off the old shrink fit retainer collar, press off the bearing & hub with a meaty press... which may result in having to replace the wheel bearing, then install new seals, put back together and install a new heat shrink collar. A Tisco dealer is the place for those seals and the new shrink collar. Around here, that's any Agco, or Ford/N.Holland dealer.
I installed sure seals a couple years back, been REAL happy with them.
George
