TO 20. correct trans, and diff oil weight.
rylan TX.
03-03-2007 19:35:39
I was told to use 90 weight trans and hydrolic fluid weight. At a tractor store i bought 10w-20. is this the wrong weight to use. thanks rylan.
John (UK)
03-04-2007 09:41:29
 Re: TO 20. correct trans, and diff oil weight. in reply to rylan TX., 03-03-2007 19:35:39
The correct description of the oil is GL1-90W and it is a straight mineral oil and although it sounds very thick like gear oil it isn't it is as thick as engine oil. Napa sell it as part # 65-205 this is 5 galls and you need 6 galls. If you want to use a Multi-grade you can use 15W-30 that oil you have is too light....John
mike a. tenn.
03-03-2007 20:00:41
rylan...i see you're form texas where you don't normally have sub-zero weather, so the correct oil for your TO-20 is straight mineral gear oil SAE-90. thru your MF dealer it's M1103-SAE90 or from NAPA GL1-90. i don't mean to sound degrading or rude but....isn't it a little backwards to go buy oil, and THEN come on the forum and ask what you should get? we all wish you would have asked us first. coulda saved ya some cash! by the way...you'll need six gallons to fill your gearbox.
hope i helped ya...mike
