TO-30 Loss of power
Mark LeMere
02-25-2007 20:00:23
Today I was plowing out from the blizzard and my 30 lost all power, revs ok and not missing, but whenever it is put under any load, it drags right down, even just putting in gear and trying to drive. Checked plugs, etc.. Wonder if a valve went? This one has a lot of use on it. Thoughts? THanks!
Mark
Jerry/MT
02-26-2007 10:12:40
 Re: TO-30 Loss of power in reply to Mark LeMere, 02-25-2007 20:00:23
My experience with carb icing has been that it has only occurs in high humidity situations during warm up and is evidenced by ratty running and visible frost on the outside in the vicinity of the carb throat. If it's that cold on the outside it's colder on the inside due to evaporative effects from the fuel. It usually disappears in about 5-10 minutes when the manifold heats up and transfers heat to the cast iron carb body. I'm not saying that's not your problem but this is my experience with carb icing.
I would check the spark at the coil secondaty output( center wire to distributor cap held near a ground with the ignion on and attempting a start) you should have a FAT, BLUISH WHITE SPARK. If that's good,check your timing and the advance mechanism with a timing light. If your distributor timing is off and/or your advance isn't working you won't develop the appropriate power. Finally, check the fuelmixture screw to make sure it isn't too rich or too lean and check the fuel delivery to make sure that you have adequate fuel to the carb.
If that all checks out, make sure that your governor is opening the throttle in reponse to a change in load. The throttle actuation rod will move in the direction of opening the throttle ( I believe that's rearward but if I wrong someone will say so) when you move the thottle lever down.
Do all these systematically(one at a time )and check to see if, when you change anything, it has any effect. That will help you figure out the problem. Get back here if you have any questions.
Jim in OH
02-25-2007 20:48:39
Could be wrong, but it sounds more like carburator icing... find a place to let it thaw or heat it and try it again.. Jim
