tef front towball
jamesgreenwood
02-22-2007 14:21:00
does anyone have a design, idea or know where I can get a front towball for a grey fergy?
John (TR)
02-23-2007 05:01:54
 Re: tef front towball in reply to jamesgreenwood, 02-22-2007 14:21:00
Here is one on ebay from a Fergy. I'm not trying to use this as a plug just as a picture to show what was on 20 and later my 35. The Ford bumpers will bolt up but won't allow you to open the hood very far. (I just looked at a Ford bumper for my 35)
jamesgreenwood
02-23-2007 16:00:21
 Re: tef front towball in reply to John (TR), 02-23-2007 05:01:54
many thanks to everyone who has repsonded to my question all your help has been very useful.
Jim
RockyMO
02-22-2007 20:34:23
This one seems to work pretty well, uses the same receiver pieces as the truck so ball size is easy to change.
Rocky in MO
third party image
mark from the fort
02-22-2007 17:29:00
I store boats in my barns during the winter and like "pushing" them around much better than backing in. Before I got a bumper with the hole for a ball, I took a 6-8" piece of 3 1/2" angle iron and mounted it to my front axle with 2 bolts. I did this closer to the tire than the center A: because I didnt want to get a trailor tongue into my grill or sheetmetal and B: I actually liked being able to see the trailor tongue as I drove up under it. Anyhow, I drilled a hole for a ball into the angle iron and it worked fine.
I am on concrete floors in all my barns so I did not put much strain on the axle. I thought having the ball mounted to the side would screw up my driving, but it worked very well.
I actually like the old way better as with a bumper mounted ball, it is VERY hard to drive up perfectly under the tongue without having to get off one or two times. Hope this helps Mark
mark from the fort
02-22-2007 17:28:54
Jeff-oh
02-22-2007 15:10:31
third party image
ebay item 250085686425. $89.00 free shipping.
This style is probally readily available at a local farm implement dealer. They are quite common. The bumpers for the Ford N series will work.
Jerry/MT
02-22-2007 14:41:34
I've seen some aftermarket bumpers that have a tab with a hole in it welded to the front. I suppose you could put a tow ball on that. It wouldn't be hard to weld something up that bolted to the front axle that would allow a tow ball to be mounted on it. You didn't say what you wanted to tow with it.
jamesgreenwood
02-22-2007 14:53:46
 Re: tef front towball in reply to Jerry/MT, 02-22-2007 14:41:34
thanks Jerry. sorry yes a caravan, complicated turns around some farm buildings, so that"s why I need to push!
