trying to convert ferguson 30 to 12 volt
Robert Martinez
02-20-2007 19:53:46
im trying to find out if i can use the conversion kit sold for the TO30 for my ferguson 30 its a 51" thanks for any help - what is the difference between the ferguson 30 and the ferguson TO30? thanks agaain
dfitch
02-22-2007 04:04:27
 Re: trying to convert ferguson 30 to 12 volt in reply to Robert Martinez, 02-20-2007 19:53:46
the following link has a lot of information about converting to 12 volts. There are several links inside this link follow and read all of them. I think you will wind up with a better conversion if you wire all the of the connections on the alternator. The hardest part of the conversion is making the mounting bracket.
I have pictures of what I did and if you want them drop me an email
http://www.geocities.com/wallaces_23/onewire.html?20066
John in MS
02-21-2007 18:24:27
Does it matter which direction the alternator rotates? I'm putting an alt on my TO-20, but the way it mounts will make it turn in the opposite direction for which it appears to be designed. That is, the cooling fins go the wrong way.
Boyde from Brampton
02-22-2007 08:30:26
 Re: trying to convert ferguson 30 to 12 volt in reply to John in MS, 02-21-2007 18:24:27
Maybe the fins are going the right direction.
The old generator fan pushed air over the generator, while the alternator fan sucks air from the back.
Boyde
Jerrycpp
02-22-2007 07:53:08
Alternators use alternating current - the little electric bugs change direction zillions of times in the blink of an eye (think positive-negative-positive-negative etc.) You can spin it either direction and it will charge the same. The only problem could be the cooling fan, but if you"re not pulling a full electric load all the time, it won"t get hot anyway.
mark from the fort
02-21-2007 05:33:39
The difference between a TO30 and 30 is the letters " TO ". I meant that as a joke.
The official name was TO 30--we lazy folk just call them a 30. The 30 is a model number--the TO was a designation as "Tractor Overseas" which meant that these were the 30's manufactured in America.
You'll lover her..... ..... we all do. Mark
Eric Stevens
02-20-2007 21:18:26
All I did was put a GM altenator on, one wire, has a built in regulator, it bolted to existing bracket and all I did was pull the pulley off of the generator and put it on the altenator and I was done.
Eric
