Seperate the axle housings?
C.T. in Va.
02-20-2007 16:05:18
Do i have to seperate the axle housings to change the pins that connects to the lift arms underneath the tractor?Or can i get to them by removing the PTO?Had it all opened about 8 years ago but can't remember or just didn't notice at the time how to remove them.Plus i have amnesia on where i put my manual.
buford
02-21-2007 17:10:39
 Re: Seperate the axle housings? in reply to C.T. in Va., 02-20-2007 16:05:18
just a thought, when you pull the quarter or axel housing remove the other rear wheel or you will damage the axel seal on the other side I learned this the hard way. seems the pig will move just enought to allow the axel to shift and damage the seal when you pull the axel from the diff. as I said just a thought
C.T. in Va.
02-22-2007 12:23:29
 Re: Seperate the axle housings? in reply to buford, 02-21-2007 17:10:39
Thanks buford,i'll have to remember that.Not really looking forward to doing it at all.Those wheels and tires are a dog to work with.Thanks again bud.
C.T. in Va.
02-21-2007 11:13:44
Mine are bent so i wonder if i should change them before they break off and fall in the housing?Thanks very much for the imput.
Dan S (NY)
02-21-2007 09:12:18
You can get to both pins by removing only the left housing and removing the differential.
Dan
chuck130
02-21-2007 04:53:31
I'm afraid you have no choice but to remove the housing.
