Timing marks on TEA-20
Serge
08-10-1999 14:42:51
Thanks to read this message...
I am searching for timing marks on my TEA-20
I checked on the crankshaft pulley and looked
for a door to flywheel...no success.
Would appreciate to know where the marks are
in order to check timing advance with timing light.
Thanks in advance !
Tex Ferguson
08-11-1999 19:23:27
 Re: Timing marks on TEA-20 in reply to Serge, 08-10-1999 14:42:51
Serge, can you stand on your head? You need to be an acrobat to find the small hole in the flywheel housing! It is located on the front vertical surface of the flywheel/clutch housing, on the left side, practically hidden by the radius rod(brace to the front axle. I found the timing hole on my TE-20 by holding a mirror between the radius rod and the crankcase. Look for a small bump, which is a small metal plug closing it off, possibly invisible under a smooth coating of dirt. Ah, the mystery of the Ferguson -- such a challenge. Good luck!
Serge
08-12-1999 06:08:22
 Re: Re: Timing marks on TEA-20 in reply to Tex Ferguson, 08-11-1999 19:23:27
Hi Tex !
Thanks for the information
Will check it this week-end
I am putting some $$ aside for a service manual
Thanks to you Tex and to guys who running this board
