TO-20 dash switches wiring// gear shift starter??
bruc
02-17-2007 02:13:24
Got a "50 TO-20. It has a two pole switch near the hood release lever under the top dash panel. What is it for? On the ignition switch (Viewed from the rear)I have 3 connections What do those hook to, from left to right?
Thank you!
Regarding the shifter, does it have a safety interlock to prevent accidental starter engagement while in operation? Thank you one and all for the assistance!
Have a good one!
Bruce
bruc
02-19-2007 20:24:44
 Re: TO-20 dash switches wiring// gear shift starte in reply to bruc, 02-17-2007 02:13:24
Just sold a 9N that I installed another solenoid on. Was not too happy with over riding the safety feature. Currently in progress to build a system that over rides the starter engagement while the engine is running.
Thanks for the help!
Bruce
Bob (Australia)
02-17-2007 15:32:20
If it is the same as a TEA20 (and I think it is) there is no safety lock-out on the gear lever starting position.
Can't help you on the starter switch, although one will be the live side of the battery (usually connects to the live side starter switch); one may be lights (or provision for lights); and the last will connect to both charge indicator and coil.
Someone will be able to give you far more accurate information on the three switch positions.
I didn't like the gear lever start on my TEA20 so installed a separate solenoid.
