MF 35 hydrolics???
Gareth
12-28-2000 12:08:44
i was wanting to know what hydrolic oil is needed for a MF 35 and is there a special place that you must put it in???
thanks in advance!!
Chip
12-29-2000 06:04:47
 Re: MF 35 hydrolics??? in reply to Gareth, 12-28-2000 12:08:44
I use Hydraulic -transmission fluid, I usually get Warren 303, or similar version from other manufacturers. You should be able to get this from a local tractor dealer, or even auto parts stores. If in doubt, ask to see their catalog, the manufacturers recommendations are usually in there. As for filling, you will find a large plug at the front of the transmission case, top left, thats where you fill it up, about 8 gallons total I believe. There are two drains on the bottom, one on the trans and one on differential case.
greg moseley
12-31-2000 08:29:57
 Re: Re: MF 35 hydrolics??? in reply to Chip, 12-29-2000 06:04:47
actually, the manual says it holds 7 gallons, I would put 6 and gradually put more until it reaches the full mark on the stick. Good luck!
