90W IN TE 20
DWAYNE DUNN
02-13-2007 13:39:03
DO YOU RUN 90W INTE 20 OR DO YOU RUN FORD HYD LUBE
gshadel
02-14-2007 18:39:01
 Re: 90W IN TE 20 in reply to DWAYNE DUNN , 02-13-2007 13:39:03
90Wt like Mike points out is the oil spec'ed out for the TE20. The Ford hydraulic oil that the Ford N.Holland dealer is pushing for the 9N & 8N will work. The N internals are basically the same as your TE.
I have heard guys complain about the Ford stuff because the lift may bleed down faster, and your pump may thump with the thinner oil, depending on the condition of your internal hydraulics.
George
mike a. tenn.
02-13-2007 13:58:23
dwayne...i run straight mineral oil that i'll either get from AGCO (M-1103 SAE 90w) or NAPA (GL1 SAE 90w) in both my TO's. i don't know if ford hyd. lube would be ok for it or not.
-mike
