Latest on SS and Electrolysis.
Jeff-oh
02-09-2007 11:50:40
At lunch I talked to a Chemistry Professor I know about the whole Hexavelent Chromium Oxide issue in Electrolysis.
Bottom Line is there is no concern.
He said, it is possible to produce Hex-Chromium with the voltages and currents used during electrolysis. However, very little would be produced and what is produced will quickly be reduced in the iron rich environment away from the hex-chromium.
On the other hand he stated that Washing soda is defiantly preferred to NaCl. As the chlorine in, Sodium Chloride (table salt) will react with the oxygen to form Chlorine Gas. As the amount of Chlorine is reduced the ability to transmit the current is reduced.
The Carbonate in washing soda will not react and will not be used up. He also stated that the addition of lye would promote the whole process, however, the hydroxide would be used up and would need to be replenished.
Thus, I will start using washing soda, and will not be concerned about using a stainless steel anode.
Jeff
HillsOfTn
02-09-2007 17:32:52
 Re: Latest on SS and Electrolysis. in reply to Jeff-oh, 02-09-2007 11:50:40
Hey Jeff,
Tnanks for the extra effort to get an educated answer. It sure supports your original point that it's a helpful contribution to question an idea or process if there are unanswered concerns - it is not good to make broad statements based on heresay and present those statements as absolute truth.
mike a. tenn.
02-09-2007 13:36:39
jeff...thanks for the update. i guess i'll try stainless after all.
-mike
hendrik
02-09-2007 12:55:50
Thanks for this information. I'm an avid user of electrolysis and stainless is my preferred material for sacrificial anodes. Stainless is far superior to plain steel IMHO. Also use washing soda :-)
Thanks, Hendrik (who normally lurks on the Farmall Board).
