Play in PTO shaft
BuckTO30 NC
02-04-2007 14:07:05
On my TO 30 is there supposed to be play in the PTO shaft or should it have none.Mine moves from side to side and up and down about 1/4 inch or a little less. If it is not right what should be checked to correct it. Thanks Guys.O
phil(va)
02-05-2007 06:53:55
 Re: Play in PTO shaft in reply to BuckTO30 NC, 02-04-2007 14:07:05
Bearing probably worn. If you have the original 1 1/8 shaft, you can replace the entire shaft and assembly with a more modern 1 3/8 shaft very easily, about $110.
