new radiator
Grass Roots Far
02-02-2007 16:50:47
My radiator is leaking again...used some kind of radiator "gunk" added to antifreeze to get through last summer, but since I changed the lower hose recently and didn"t add any sealer, the problem is back. How long can I go with putting more additive? How difficult is it to install a new radiator on a TO-20? Stains on the bottom 1/3 of the radiator indicate the leak has been going on for quite q while. I have had the tractor 6 years. I have no idea how old the radiator is. I may have to bite the bullet and get a new radiator. Any ideas? Thanks in advance.
Just 1 More
02-05-2007 12:22:42
 Re: new radiator in reply to Grass Roots Farmer, 02-02-2007 16:50:47
my loacal radiator shop wanted more to re core mine than it did to order a new one.. I'm much happier with the new readiator (so is the tractor) and I did the replacement out in the field where it was parked.. not a hard job, just had to fight with a couple bolts, but thats to be expected wit the age.
mike a. tenn.
02-03-2007 15:07:05
GRF...if you take your radiator in to be repaired, ask them how they're gonna repair it. some radiator shops will find the leaking tube and just close it off, where others will re-core the whole thing. totally recoring it is the only way to go. don't let them just repair the leak by closing off the leaking tube as this takes away part of it's cooling efficiency. recoring costs more but is better...you might want to check the price of a new one to compare it to the repair cost. i'd suggest that you make sure you have a good working temp. guage, and keep your eye on it from time to time when working with your 20. you don't want it to ever overheat, as this is one of the things that cause the dreaded cracked block problem so typical of to-20's. having a poorly repaired radiator is a bad thing for a 20...make sure you get it done right.
just my 2 cents worth
-mike
phil(va)
02-03-2007 14:24:22
No problem to remove and reinstall. As mentioned, any auto radiator shop will be able to help you most likely. Most of the new ones are made in China and not as good metal and more expensive than repair in most cases. If you don't have a thermostat installed, you should install one when you reinstall the radiator.
John (TR)
02-02-2007 21:21:49
2 bolts on the bottom and 2 hoses, not too bad at all. It might be worth taking to radiator shop (provided you can still find one) and have it cleaned out and repaired. I had the one for my 35 at the shop in August and it was 75.oo for 4 leaks and cleaned out. New radiators start around 150 and go up
Grass Roots Farmer
02-03-2007 07:10:04
 Re: new radiator in reply to John (TR), 02-02-2007 21:21:49
Hey, thanks for the reply. Yes, I will contact the former tractor owner and see how old the radiator is and also check out charges at a radiator repair shop. good ideas.
