Buried in a lower discussion was a request to explain how electrolysis works.Basically speaking you are breaking down the water molecules into oxygen and hydrogen. In this process the black oxide is formed on one piece while another sacrificial piece is eaten away, (if it reacts) To make the process work you need 3 things. 1) A suitable "Non-conductive" container (plastic bucket etc.) I have even made temporary containers out of 2x8's nailed in a square on the ground and lined with black sheet plastic. Anything that will hold water and not conduct electricity will do. (garbage can, cat litter pail etc) 2) A low amp eclectic supply. Most use 2 or 6 amp battery chargers. No plugging into a wall outlet, as you do not want to be electrocuted. 3) An electrolyte. Water by itself is not a very good conductor of electricity, however it easily dissolves molecules that will ionize. (now for the high school chemistry.) An electrolyte is a substance containing free ions that behaves as an electrically conductive medium. Electrolytes are normally formed when a salt is placed into a solvent such as water and the individual atomic components are separated by the force applied upon the solute molecule, in a process called chemical dissociation in which the solution applies force to hold the ions apart. Salts are compounds that are linked by weak ionic bonds, and will separate into charged ions in the presence of a solution containing stronger covalent bonds. Uhh, the salt desolves and breaks up into a positice ion and a negative ion, and thus will conduct electrocity. The during the process the negative ions (anions) flow to the positive terminal of the electric source (anode) and the positive ions (cations) flow to the negative terminal (Cathode). Through this process you convert the rust to Black oxide which is a more stable form of iron oxide. Goto wikipedia and search onb rust to see the chemical process. I think I digress too much. To you need a electrolyte. Many people claim, I think based off of Frank in Tennessee�s electrolysis article that you need washing soda, laundry soda or the like. True it will give you a nice electrolyte. However, I use a much cheaper substance. Rock salt. I.e. like for making home made ice cream, or for melting ice off the side walk, or for use in water softeners. All you are looking for is something to get the electric flowing through the water. (Table salt is not an economic solution) Now to get started, you got your bucket, water with salt desolved, (I use ~ 1 tablespoon/ gallon) and electric supply. I then take the part(s) I want to treat and put them in the water. (use copper wire on small parts (bolts, nuts, washers, etc)). I then connect the positive �Black� clamp on the part/ wires. The parts are now you cathode. Next, place you annode into the water. Make sure the annode is long enough to stick out of the water and place your Positive �red� clamp on it. A nice piece of stainless steel makes a great annode. If you do not have one handy and piect of scrap metal will do. Be prepared, as the annode will be eaten away druing the process and be slowly destroyed. I have used old lawn mower blades, angle iron, a shovel head etc. Just do not put your battery charger clamp under water as you will destroy it. Out of the water it will be fine. Polarity of you electric is critical. A simple rememberance I use is the Red lead rusts (Red-rust) and the black lead un-rusts (Black-Black oxide) Make sure the two pieces of metal are not touching and plug in the charger and watch her bubble. The process will take time. 10 to 12 hours. Cycle the parts through the bath. The water will become cruddy looking but it is still fine. Use a wire brush to clean the annode (red clamp) as needed to keep the amperage up. Often brushing off the part once in a while will help speed the process. One final thing, you cannot over do it. So when you and the parts are ready pull then out rinse them off and dry them and then paint then and on to the next piece. Good luck. Sources: wikipedia.org Paul Nelson�s excellent article in FENA�s Ferguson Furrows #16. Available from Paul for $3.00 US ($3.50USD Canada) See Paul�s posts for his e-mail.
