Throttle Linkage
DennisPinOhio
01-31-2007 07:48:45
Today, I had a "dead throttle" condition. Found throttle linkage to the quadrant was unseated. Question: is there supposed to be a spring clip (or some such thing) that holds the linkage socket(s) onto the ball pivots?
Mike Mohrhauser
02-01-2007 05:53:14
 Re: Throttle Linkage in reply to DennisPinOhio, 01-31-2007 07:48:45
Dennis,
I think you are talking about the linkage rod between the throttle lever and throttle control plate.
It sounds like the ball ends have worn out. Letting the ball fall out of the socket. You should be able to find new replacement ends at an automotive parts store.
Mike M.
Irv ( Ia)
02-02-2007 19:29:35
 Re: Throttle Linkage in reply to Mike Mohrhauser, 02-01-2007 05:53:14
Those are little rascals to get out of there too. The one that hooks onto the throttle rod disc is threaded in and isn't normally hard to turn but takes small hands and nimble fingers. Preferrably no bifocals, too! LOL
DennisPinOhio
02-01-2007 14:47:00
Thanks, Mike. That is exactly what happened. When I put them back onto their respective pivot ball, they did not fit tightly or snap into place. So I am sure you"re right - they"re worn out.
I"ll try NAPA for replacements.
Thanks.
Dennis
DennisPinOhio
02-01-2007 05:28:41
Thank you for the reply;
Is there a picture somewhere that shows this assembly?
I"m having trouble picturing what you"ve described.
Thanks again.
Dennis
Jerry/MT
02-01-2007 09:58:08
 Re: Throttle Linkage in reply to DennisPinOhio, 02-01-2007 05:28:41
It's in the Ferguson Parts Manual but Idon't have a scanner or a fax to send it to you. Holler for John(UK). I think he has that capability.
Jerry/MT
02-01-2007 09:57:45
Jerry/MT
01-31-2007 20:55:47
There is a ball socket link that attaches to the governor linkage rocker with a nut and connects to the governor lever arm rod.
