changing oil seals
BuckTO30 NC
01-31-2007 06:36:39
The oil seals are shot on both sides of my to30.The bearings seem to be ok. My question is should I go ahead and change the bearings since I have to remove the shaft collar and may have to replace them shortly if they go bad.
John (UK)
02-02-2007 06:09:39
 Re: changing oil seals in reply to BuckTO30 NC, 01-31-2007 06:36:39
Clean and wash the bearings and if there is any roughness at all then change them, make sure you fit the new seals the correct way. Don't forget to pre-pack the bearings with grease. Do fit new gaskets either side of the brake back plate, the shims fit next to the end of the Axle Housing, then a gasket, then the back plate, then a gasket. You would be surprised how many get that wrong.The Sparex part numbers are:- S42078 seal and collar kit, S18516 Bearing, S42622 gasket (2 each side) These are for the normal TO30 if yours is one of the late ones it could have a TO35 axle fitted and the parts will be different, check the number stamped in the bearings, if it is 4T-3780 on the inner cone then it is the old type, if it is 4T-462A then it is the TO35 type, email me at:- fergusontractors(at)tiscali.co.uk
if you need the other part numbers for the TO35 type.....John
phil(va)
01-31-2007 21:13:48
I would.
