to-20 problems major
j dale
01-30-2007 17:34:33
cracked block between cylinders any suggestions ran fine just leaked lots of water into the oilpan
Tom H.
02-02-2007 04:46:06
 Re: to-20 problems major in reply to j dale, 01-30-2007 17:34:33
Just to add another option, I had my TO 30 block bolted or pinned between the sleeves by my Massey dealer service dept. They stated that that was how they had fixed the blocks for 40 years without any problems. Either way you have it done it will still come out as a complete rebuild. Find a set of micrometers and check all of of your tolerances. I was lucky enough to not need to only have to get over (or under) sized bearings for the crankshaft that I had replaced and my sleeves were not worn and only needed a quick honing. Don't get discouraged by this job. If you have garage space it is very straight forward and you will have a lot of help here.
Good luck,
Tom
paul in Ms
01-31-2007 03:39:23
There is a to-20 block on Ebay. Ebay # 250079626525
Jim in OH
01-30-2007 18:30:03
Do you want to try something simple and run it or rebuild it? Here is an email answer that I got from Bars... Don't know if it works, but worth a try... and most of the time, these cracks are fixable with furnace brazing... but require complete removal and rebuild... do a search here for cracked blocks or furnace braze... lots of info available... JIm
-----Original Message-----
The following is the contents of a form submitted on 16-Jan-07 at 11:08 AM:
TO: [email protected]
SUBJECT: Questions about applying or installing our products
DESCRIPTION: Which one of your products would you recommend to seal seeping cracks in an engine block from the coolant jacket to the oil crankcase? Thanks, Jim
Try product C16, Radiator Stop Leak. This can be found at most automotive stores, as well as K-Mart and Meijer.
Mary A. Doty OEM Coordinator
Customer Service Rep.
[email protected]
steve19438
01-31-2007 05:30:44
 Re: to-20 problems major in reply to Jim in OH, 01-30-2007 18:30:03
i used bars leaks in a to-20 many years ago. worked great until i added anti-freeze for the winter. the "AF" went right into crank case.
Jerry/MT
01-30-2007 18:20:36
Common problem for the Z series Continental blocks if they have been overheated. Your looking at rebuilding the engine. The block needs to be repaired. Furnace brazing is the best method with the added advantage of the block being stress relieved in the process. The cost is competive to finding a used block usually. Talk to a good machine shop and get a cost estimate. You can buy a remanuafactured engine for about $1800-2000 or if you have the inclination and the normal mechanics hand tools, you can have the machine shop due the hard parts and you can reassemble the engine with new sleeves, rings and earings for about half of those numbers.
