Ferguson TO30 Hydralics
Jim VanLinn
01-28-2007 10:33:49
I have a fergusion TO30. The hydralics on the hitch come up real slow or not at all. What should I check? Need Help!!
Jerry/MT
01-28-2007 18:47:31
 Re: Ferguson TO30 Hydralics in reply to Jim VanLinn, 01-28-2007 10:33:49
Pull the right side access cover and with the engine running, move the lifdt control lever to the lift position and look up toward the lift cylinder. If you see more than a few drops of oil coming down, you have leaking hyraulic piston rings or a cracked lift cylinder. If that looks OK look in the front right hand corner of th pump chamber and see if the gasket on the piston supply tube is leaking oil. Check to make sure that the wishbone on the control valve is connected. Finally, make sure the control valve is not stuck open.
look upwar
John (UK)
01-28-2007 13:54:43
 Re: Ferguson TO30 Hydraulics in reply to Jim VanLinn, 01-28-2007 10:33:49
I have done a couple of replies on this subject already, it isn't 90W gear oil you need it is GL1 90W which is thinner and totally different oil, you can also use 15W/30 Multi-grade oil if you are in a cold climate it will not go as thick when cold. If the oil is thicker than you would use in a truck/car engine it needs to be changed, if it is just as thin then it could be the Control Valve sticking maybe not travelling the full movement due to wear or just sticking. If you need help with this I have service Information for this, just email me at:- fergusontractors(at)tiscali.co.uk
if you need it, just tell me again what the problem is and I can be sure to send you the right Info and pictures.....John
mike a. tenn.
01-28-2007 11:59:47
jim...your trouble could be due to many different possibilities. start with the easy ones...is your gear box oil level full? do you have the correct gear oil? is your gear oil old and dirty? how cold is it where you are, did you allow it to warm up for a while if it's real cold out?
i would check these things first and if these are all ok then you might have other problems. let us know what you find.
-mike
mike porter
01-28-2007 11:58:38
1st thing is to replace your hyd. oil with 80/90EP oil, available from tsc stores. w/o the correct oil, ferguson hydraulics suck! next, check there's enough oil in it. it holds 7.0 gallons. next, make sure the check valve is ok.
John (UK)
01-28-2007 13:41:53
 Re: Ferguson TO30 Hydraulics in reply to mike porter, 01-28-2007 11:58:38
80/90 EP oil is wrong it should be GL1 80 or 90 w il which is like the oil you would use in a car engine...EP oil is not suitable for the Hydraulics as it is too thick and contains certain sulfurous additives that will eat away the Yellow metals in the Pump and Diff and G/box. The mistake is often made over this oil due to the rating they use, at first glance it appears to be the EP variety but it is incorrect.
mike a. tenn.
01-28-2007 12:03:36
 Re: Ferguson TO30 Hydralics in reply to mike porter, 01-28-2007 11:58:38
mike...my book says that a TO-30 holds 6 gals of gear oil. am i looking at the wrong thing?
-mike
John (UK)
01-28-2007 13:46:32
 Re: Ferguson TO30 Hydraulics in reply to mike a. tenn., 01-28-2007 12:03:36
It isn't gear oil it is GL1 90W which is not the same as 90W EP gear oil. you can use 15W/30 Multi-grade as well, this will remain thinner than the GL1 type if you are in a cold climate and will help the oil to flow in the Pump.
mike a. tenn.
01-28-2007 14:19:10
 Re: Ferguson TO30 Hydraulics in reply to John (UK), 01-28-2007 13:46:32
john...i just refer to it as gear oil to differentiate it from cankcase oil. i get mine right from my AGCO-MF dealer. i ask for the straight mineral oil, M1103-SAE-90. is this the same as the GL1 you referred too?
and...how much DOES the TO-30 take. my TO-20 takes 6 (US) gals. isn't the 30 the same capacity?
-mike
John (UK)
01-29-2007 07:22:31
 Re: Ferguson TO30 Hydraulics in reply to mike a. tenn., 01-28-2007 14:19:10
The M1103 oil is correct, it causes quite a lot of confusion when they say 90W, (lots of people think that it is the gear oil because it is in the gearbox and the Axle they seem to forget it is in the hydraulics too) and we get this a lot on here, I was just making sure that you did have the correct oil. To confuse matters even more, the oil we used over here in the UK when the tractors were still in production was the same as we used in the engine which was SAE30/40 and it was approved by the factory for use. The oil capacity is 6 US gallons same as the TO20 and the TE20's....John
GL1 80W or 90W straight mineral oil NAPA part # 65-205 or MF1103
phil(va)
01-28-2007 20:23:44
Yes, six (6) gallons for the TO-30.
Just 1 More
02-01-2007 07:47:16
 Re: Ferguson TO30 Hydraulics in reply to phil(va), 01-28-2007 20:23:44
NAPA has the GL1 that you need.. PArt # 65-205 for about $26.00 / 5gal.. and yes.. 6 gallons is what it holds
