for john (tr) and lonestarjeff...measurement
mike a. tenn.
01-26-2007 15:20:28
on the hydr. control bracket i made...i welded the mounting plate for the control, on the 5/16 cross piece, and the measurement for that is 41/4" from the center of the frontmost fender bolt to the front edge of that plate. this will give you the best hose fitting clearance from the lift arm. (hope you can understand what i'm describing)
-mike
lonestarjeff
01-26-2007 18:06:05
 Re: for john (tr) and lonestarjeff...measurement in reply to mike a. tenn., 01-26-2007 15:20:28
Thanks Mike, well described.
BTW, I meant to ask how you patterned the curve in your canopy supports.
Jeff
mike a. tenn
01-26-2007 20:39:35
 Re: for john (tr) and lonestarjeff...measurement in reply to lonestarjeff, 01-26-2007 18:06:05
jeff...that's kinda hard to describe, but basically i clamped my flat stock together with the original support brackets in a large vise and bent the flatstock around it while heating it with a torch. this got me "close". after that it was just kind of an "eyeball" thing with just the flatstock in the vise, using the original support for a guide. you'd kinda have to see the original support to see why i had to finish it "by eye", but hope this helped.
-mike
lonestarjeff
01-26-2007 20:57:59
 Re: for john (tr) and lonestarjeff...measurement in reply to mike a. tenn, 01-26-2007 20:39:35
Thanks again Mike. I do lots of things by the "eyeball" method.
Jeff
